gary42206
#1 Posted : Monday, April 19, 2010 9:11:32 AM(UTC)
gary42206
I have dryer model number len2000jq1. It is not drying like it should. I watch dryer elements come on for about 15 seconds then they kick off wait 2 mins come back on for 15 seconds..its either Thermal cut-off part number- AP3094244 or its Thermostat, fixed part number AP3131941 can you help me on which one i should order.
magician59
#2 Posted : Monday, April 19, 2010 10:23:03 AM(UTC)
magician59
It could be a bad heat selector switch, or the cycling thermostat. Part number: AP3045874
#3 Posted : Tuesday, April 20, 2010 1:12:21 AM(UTC)
Undo the dryer from the exhaust
Run a load
If the load dries correctly then you have a vent problem.
Clean/check the vent system. Make sure the outside louvers open fully.
If you do not want lint in the house.
Take a pair of pantyhose, put one leg into the other and attach this to the dryer exhaust.
Leave enough room behind the dryer so it can blow out like a windsock.
Run a load.
Both the above will allow you to check the air flow and temp.
RE: Hello (Washer Repair)
by robertee 10/24/2011 5:56:11 AM(UTC)
Hello (Refrigerator & Freezer Repair)
by nardone3 9/9/2009 7:01:40 AM(UTC)
by tmilano911 7/3/2009 7:06:02 PM(UTC)
