I have dryer model number len2000jq1. It is not drying like it should. I watch dryer elements come on for about 15 seconds then they kick off wait 2 mins come back on for 15 seconds..its either Thermal cut-off part number- AP3094244 or its Thermostat, fixed part number AP3131941 can you help me on which one i should order.
Undo the dryer from the exhaust Run a load If the load dries correctly then you have a vent problem. Clean/check the vent system. Make sure the outside louvers open fully.
If you do not want lint in the house. Take a pair of pantyhose, put one leg into the other and attach this to the dryer exhaust. Leave enough room behind the dryer so it can blow out like a windsock. Run a load.
Both the above will allow you to check the air flow and temp. |
THIS FORUM IS DEAD!!!!!!! |
