icecold 40
#1 Posted : Wednesday, April 14, 2010 6:49:26 AM(UTC)
icecold 40
i cant figure out how to get the oven door hinges off the stove.there is 2 screws on each hinge and after i had took them off i cant figure out how the hinge comes out off the stove.thank's
#2 Posted : Wednesday, April 14, 2010 12:38:18 PM(UTC)
Open the hinge about half way, and holding it in this position pull it up and pull out the bottom of the hinge through the slot in the frame.
icecold 40
#3 Posted : Wednesday, April 14, 2010 5:14:24 PM(UTC)
icecold 40
hi gene,i tried what you said but it seems the bottom part of the hinge will not come threw the slot,seems like the hinge is to big to fit threw.
#4 Posted : Friday, April 16, 2010 8:03:41 PM(UTC)
If it does not come out, then you probably have to remove the side panel.
icecold 40
#5 Posted : Friday, April 16, 2010 8:27:05 PM(UTC)
icecold 40
how do i do remove the panels??
#6 Posted : Friday, April 16, 2010 8:39:33 PM(UTC)
icecold 40
#7 Posted : Sunday, April 18, 2010 12:46:11 PM(UTC)
icecold 40
thank's gene the manual was awesome help,you tha man!!:)
#8 Posted : Monday, April 19, 2010 6:57:33 PM(UTC)
You are welcome. Good luck with your range and keep us posted.
