i cant figure out how to get the oven door hinges off the stove.there is 2 screws on each hinge and after i had took them off i cant figure out how the hinge comes out off the stove.thank's
Open the hinge about half way, and holding it in this position pull it up and pull out the bottom of the hinge through the slot in the frame.
hi gene,i tried what you said but it seems the bottom part of the hinge will not come threw the slot,seems like the hinge is to big to fit threw.
If it does not come out, then you probably have to remove the side panel.
Originally Posted by: Gene  If it does not come out, then you probably have to remove the side panel.
Gene. how do i do remove the panels??
thank's gene the manual was awesome help,you tha man!!:)
You are welcome. Good luck with your range and keep us posted.
