jgmace
#1 Posted : Monday, April 19, 2010 5:11:30 AM(UTC)
jgmace
Is there any way to test the Timer Resistor for this dryer. The timer works normally in regular timer mode but will not advance on the Permanent Press or Auto Cycle. I found the information below on another site and this part is present in my dryer.
Auto or Permanent PressSome dryer models use a SPDT thermostat to control the advancing of the timer in the 'auto' or 'permanent press' cycle as described above. Others (older Whirlpool built models especially but also some newer Frigidaire and GE dryers) have a resister in series with the timer's motor which only allows power to flow to that motor when the heater is cycled off by the control thermostat. On the latter design should this resister fail, it will stop the timer from advancing in the auto dry mode but will still advance normally on regular timed cycles.
#2 Posted : Tuesday, April 20, 2010 1:01:56 AM(UTC)
Replacement parts for General Electric DPSR473EW0WW Electric dryer | AppliancePartsPros.com
Measure it with a meter should be around 5,000 ohms.
I cannot find tech info on this unit so the above is approximate.
Also often GE's use two elements in the heater, if one of them is burned out this will stop the timer from advancing in auto mode.
The way it works is that when the heater is shut off by a thermostat the timer motor gets it's power through the heating coil and the resistor drops the heater's 240 volts down to 120 volts for the timer motor.
If you do not have the wiring diagram take a look in the control console, they like to put them in there.
jgmace
#3 Posted : Sunday, April 25, 2010 7:27:14 AM(UTC)
jgmace
Thanks for the info. I checked the resistor and it was ok. Took the machine apart and found the inner coil had broken. I have ordered a replacement coil kit, belt and a light bulb we didn't even know we had. I plan to reuse the heat shield with the new coils.
Once again, thanks for the advise.
Guest (4)
