2 Pages<12
lusien
#11 Posted : Sunday, April 18, 2010 10:31:32 AM(UTC)
lusien
I'm glad you were able to fix it. Be careful with the self clean next time. It's better not to use it at all.
I hear that. Are you still broken? Phil
ratkinso
#12 Posted : Wednesday, November 24, 2010 5:54:04 PM(UTC)
ratkinso
We have a Kitchenaid oven model KDRP407HSS13. Last year I had an error on the display and after some research, I replaced the fuse behind the control panel. Now the oven gets power to the contol panel and to the oven lights and no errors. When I select any baking option and hit enter, the oven does not heat up. I read on this forum that there is another thermal fuse behind the oven just above the convection fan (which I have located).
Can I bypass the fuse using a jumper wire to see if that is the problem before I order a new fuse?
2 Pages<12
