2 Pages12>
Island Joe
#1 Posted : Monday, April 28, 2008 8:21:11 PM(UTC)
Island Joe
After rinse cycle is complete, the washer fails to drain.
Where to start?
Thanks, Island Joe
GE Profile Quiet Power II fails to drain
Model: GSD40204BB
#2 Posted : Tuesday, April 29, 2008 5:49:40 PM(UTC)
Joe,
Can you be more specific on the problem?
Island Joe
#3 Posted : Tuesday, April 29, 2008 7:17:57 PM(UTC)
Island Joe
Hi Gene,
Thanks for the reply. The dishwasher completes a full cycle, cleaning well, but when it's over and you open the door, the bottom is still full of water.
#4 Posted : Wednesday, April 30, 2008 11:29:46 AM(UTC)
Hi Joe,
The first thing I would check is the air gap (if there is one) on top of the sink. Remove the cover and the top piece and check for a clog.
Remove the drain hose form the air gap (or from the garbage disposer if there is no air gap), put the end of the hose in a bucket, run the drain cycle and watch for a foreign objects coming out.
If there is nothing wrong then it could be a kinked drain hose or a drain pump. For more accurate advise I need the complete model number of the dishwasher.
Island Joe
#5 Posted : Wednesday, April 30, 2008 4:55:06 PM(UTC)
Island Joe
Hi Gene,
Thanks for your note - the model is: GSD40204BB
Joe
#6 Posted : Wednesday, April 30, 2008 5:03:51 PM(UTC)
Joe,
The model number consists of: 3 letters - 4 digits - 1 letter - 2 digits - 2 letters.
Island Joe
#7 Posted : Wednesday, April 30, 2008 5:32:32 PM(UTC)
Island Joe
Hi Gene,
Sorry.
Model #: GSD 4040 Z 04 BB.
Joe
#8 Posted : Wednesday, April 30, 2008 6:24:39 PM(UTC)
Thank you, Joe
Do what I recommended first and post the results.
Island Joe
#9 Posted : Thursday, May 8, 2008 4:51:29 AM(UTC)
Island Joe
Hello Gene,
Sorry to be so long responding.
1) There is no air gap
2) no garbage disposal
3) drain from dishwasher connects directly to sink drain line, just above the elbow/trap
4) I disconnected the washer drain line from the sink drain line, partially filled the washer then hit reset to drain it. It did drain out of the dishwasher drain line, all over the cabinet and floor - no, just kidding - I had a bucket. All the water did drain into the bucket from the washer.
5) Reconnected drainline to sink line, ran a whole cycle with dirty dishes. Cleaned well, but.... the washer was full of water in the bottom that didn't drain after the cycle.
6) FYI, the sink the washer drain line hooks into drains ok, but not fantastic.
Do I have a ghost?
Joe
Island Joe
#10 Posted : Thursday, May 8, 2008 5:33:06 PM(UTC)
Island Joe
Hello Gene,
Further checking.
I was able to make the dishwasher drain completely.
But only by starting a new normal cycle, then hitting reset after a 5 seconds and letting it drain. I had to repeat that process 5-6 times before it fully drained the washer. I had made sure the trap and line was completed clear first. Also, I was able to see a clear, seemingly normal, flow of draining using a flashlight to look down the sink drain. It's just that it took 5-6 reset cycles to give the pump enough time to empty the washer.
Must not be any clogging or kinking or even pump issue. A control issue of some sort?!
Joe
Guest (13)
2 Pages12>
