AppliancePartsPros.com
Appliance Repair Help
Refrigerator & Freezer Repair
Install instructions for the TRIM around water/ice dispenser in GE Refrigerator
I just ordered the TRIM from AppliancePartsPros for my GE Refrigerator, Model TFX22PRBB WW. The Trim Part number and description is AP2069774 (WR38X10109) - Trim. I was told that I can get the Installation instruction help by coming here. Please let me know what is the correct way (how to) to install this TRIM when I get it in a few days. Thank you.
It's pretty simple and you'll see it as soon as you will receive the part. It has tabs around as shown on the following picture:  Gene.
Yes, i did saw the clips. But how does it go in -- do I start at the bottom and slide up towards the top, and then push hard all around for the clips to click or what. Or, do I just overlay on top of the mounting underneath and then push hard for it to snap in place? Thanks again.
I do not see any difference. Looks pretty same to me.
Originally Posted by: Gene  I do not see any difference. Looks pretty same to me.
Gene. don't understand your last comment. The tabs are all different - top has three longer ones, bottom has 4 short ones, and the two sides have three but they are much longer. And, if you overlay this trim on top of the mount, it will not just go in. You will have to hard-press for them to snap into the mounting frame, or, you will have to slide it in and then press to snap the tabs. There has to be a correct process to remove this trim and to put it back on.
