dwmchill
#1 Posted : Monday, April 12, 2010 5:46:57 PM(UTC)
dwmchill
Our GE washer fills okay during the wash cycle but when it comes to the rinse cycle it won't fill at all or just drips a little bit. I tried replacing the control assembly (on the advice of the local appliance shop) but it didn't solve the problem. I've ordered a pressure switch to see if that solves the problem. Anyone have any ideas what else could be the solution? Thanks in advance.
magician59
#2 Posted : Tuesday, April 13, 2010 7:37:04 AM(UTC)
magician59
It sounds like your water valve is clogged up on the cold water side.
