dflee48
#1 Posted : Monday, April 12, 2010 7:54:51 AM(UTC)
dflee48
How is this unit attached to the cabinet?
magician59
#2 Posted : Monday, April 12, 2010 10:41:31 AM(UTC)
magician59
Look real close at the trim. You should see four screws, holding the trim pieces to the cabinet (unless you have an over-the-range model). Removing the trim should allow you to slide the microwave out of the hole. If you have the OTR model, You'll find two or three screws in the cabinet right ablve the MW. Removing them will allow the oven to be tilted down and removed from a bracket along the rear wall.
Solved: Removing microwave unit from wall mounted Oven/Microwave combo (Oven Repair (including Ranges and Cooktops))
by MalikR 6/10/2024 3:04:18 PM(UTC)
Removing Microwave Control Panel (Microwave Repair)
by bradf79 9/25/2016 5:31:57 AM(UTC)
Removing microwave from wall combo (Microwave Repair)
by James Seagroves 10/29/2015 5:06:51 AM(UTC)
Removing microwave (Microwave Repair)
by dannn 11/3/2007 11:05:56 AM(UTC)
