Glen65 - Thanks so much for picking up on such a minute issue. I will have to wait a couple weeks to compare the pdf to my situation, but could you answer 2 questions? First - should I have replaced the cold control thermostat with the newer model as per yur first pdf service bulletin? Second - once everything is correct, will the fan in the freezer still run all the time (except for defrost cyles) or when properly running, does the freezer fan only come on as dictated by the cold control thermostat? Thanks again.
