I need to replace the oven light switch of my duel fuel 40 inch two oven stove
no I need to replace part ap2135799 the switch that turns light on and off when oven door is opened and closed not the back guard oven light switch which turns on oven light while closed
This switch ![UserPostedImage](http://www.appliancepartspros.com/PartImage.aspx?imgid=Z3BqLjBfbXNfMTEyNDEzMTAzNS9JQ1cvc290b2hwdHJhcC8%3d) has two latches which should be pushed in to let the switch to be pulled out. Most often it's not possible without breaking the old switch in pieces. Your choice is to break the old switch and pull out all pieces or to remove the side panel (instructions are attached). Do not forget to remove the power from the range. Gene.
Thanks so much for info I am unable to open file as sent is there another way to send
