cmruddy
#1 Posted : Friday, April 9, 2010 8:50:12 AM(UTC)
cmruddy
I need to replace the oven light switch of my duel fuel 40 inch two oven stove
magician59
#2 Posted : Friday, April 9, 2010 10:21:34 AM(UTC)
magician59
cmruddy
#3 Posted : Friday, April 9, 2010 10:50:01 AM(UTC)
cmruddy
no I need to replace part ap2135799 the switch that turns light on and off when oven door is opened and closed not the back guard oven light switch which turns on oven light while closed
#4 Posted : Friday, April 9, 2010 3:48:29 PM(UTC)
This switch
UserPostedImage
has two latches which should be pushed in to let the switch to be pulled out. Most often it's not possible without breaking the old switch in pieces.
Your choice is to break the old switch and pull out all pieces or to remove the side panel (instructions are attached). Do not forget to remove the power from the range.
File Attachment(s):
Dual fuel range - Removing the side panels.doc (820kb) downloaded 85 time(s).
cmruddy
#5 Posted : Saturday, April 10, 2010 6:01:55 AM(UTC)
cmruddy
Thanks so much for info
I am unable to open file as sent is there another way to send
Replace Oven Light Switch (Oven Repair (including Ranges and Cooktops))
by Driller_D78 12/21/2010 8:32:51 AM(UTC)
