What Part Do I Need If The Dryer Is Not Heating Up????:(
Could be anything, from the timer; thermostat(s); thermal fuse; heater element; or the door switch. You can first verify that you're getting 240VAC at the outlet. We can narrow down your search by leading you through the diagnosis.
