Legaleye1
#1 Posted : Monday, April 5, 2010 10:07:03 AM(UTC)
Legaleye1
Stopped freezing. Cleaned it up and blew out dust, etc by compressor. Compressor is warm. Restarted it and it freezes a small portion of shelf where detector coil is. Won't freeze rest of shelve(s). No sound at all, but there never was, even when working properly. Is this a low freon problem?
#2 Posted : Tuesday, April 6, 2010 3:05:58 AM(UTC)
[COLOR="Blue"]Is this a low freon problem?[/COLOR]
Yes it does sound like a low freon problem.
Confirm that the compressor is running all the time, you should be able to feel it vibrating.
If it does run continuously then I would say it is low freon.
Probably bets to get a new unit.
Threre is no use adding freon unless the leak can be found and repaired.
This will be expensive as you will need a pro.
