Stopped freezing. Cleaned it up and blew out dust, etc by compressor. Compressor is warm. Restarted it and it freezes a small portion of shelf where detector coil is. Won't freeze rest of shelve(s). No sound at all, but there never was, even when working properly. Is this a low freon problem?
[COLOR="Blue"]Is this a low freon problem?[/COLOR] Yes it does sound like a low freon problem. Confirm that the compressor is running all the time, you should be able to feel it vibrating.
If it does run continuously then I would say it is low freon.
Probably bets to get a new unit. Threre is no use adding freon unless the leak can be found and repaired. This will be expensive as you will need a pro. |
THIS FORUM IS DEAD!!!!!!! |
