psulee
#1 Posted : Friday, April 2, 2010 6:55:11 AM(UTC)
psulee
Within the past week we have been experiencing marks and holes on our clothes from the dryer. The dryer is also quite loud and seems to have a grinding sound. The tumber seal looks to be a possible issue are there other items I should also investigate? The dryer is about 10 years old, can we expect another 10 years or is it approaching the end of life? Thank you.
#2 Posted : Monday, April 5, 2010 2:51:46 AM(UTC)
Replacement parts for AMANA DLE330RAW Dryer - Ele | AppliancePartsPros.com
Here is a tech sheet
http://www.servicematters.com/maytag_library/docs/RT3220013R0.pdf
And a manual
http://www.servicematters.com/maytag_library/docs/RS3200007R0.pdf
Odds are the front glides and felts also need replacing, see section 4 in the parts.
While you have it opened up you may as well check all moving parts for wear.
Basically give it an overhaul.
Give the interior a good cleaning including the blower wheel.
Also clean/check your vent system.
I cannot see why you should not get at least another 5+ years out of it.
