feanor387
#1 Posted : Thursday, April 1, 2010 8:04:25 PM(UTC)
feanor387
I have two questions
1. My Freezer stated making a rattling noise all of a sudden. If I put my hand on on the back panel you can feel the vibration through the panel. Is this the fan or a thermostat. The unit started making the same noise briefly last summer then stopped when the weather got cooler. to check the fan and thermostat. If I unplus the unit and let it sit all day it will stop rattling.
2. I attempted to take off the back panel to check the fan but the stop shelf will not come out. How do you remove a wire frame shelf that has the two ends stuck in holes on either side of the unit. I would like to check for ice when it starts rattling but cannot remove the panel because of the shelf.
Thanks in Advance
Troy.
katethegreat
#2 Posted : Friday, September 10, 2010 11:23:39 PM(UTC)
katethegreat
It is probably ice buildup. I just dealt with this issue...my roommate recently turned the freezer temperature to max cold and ice started building up in the back near the fan. To fix it, I turned the temp to the very lowest setting (temporarily turning it off) and the noise stopped. Then I reset the temp to the middle setting. Hope this helps
