johnbrown
#1 Posted : 17 years ago
johnbrown
Elements will not go down to low heat. Still too hot on low. Oven works fine. Local technician has replaced terminal block at incoming pigtail, and all 4 manual control switches. No change. :confused:
misterfixall
#2 Posted : 17 years ago
misterfixall
if burners get red on high ,and then red goes when turning down ,it maybe normal for this range, unless wattage of burners is not correct , if these are original burners ,i would doubt that
johnbrown
#3 Posted : 17 years ago
johnbrown
OOOkkkaaayyyy!!! How do you recognize the wattage on an existing burner? And are other wattages readily available?
misterfixall
#4 Posted : 17 years ago
misterfixall
the wattages should be engraved on burner. call whirlpool they should be able to tell you correct wattages with model#
