Sully04Mike
#1 Posted : Tuesday, March 30, 2010 10:32:39 AM(UTC)
Sully04Mike
My Kenmore 90 series washer fills, but won't agitate or drain. There is a hum for a short time then all is quiet. I took it apart and the coupler looks fine. All the parts seem to spin freely execpt for the water pump is stff.
magician59
#2 Posted : Tuesday, March 30, 2010 11:16:01 AM(UTC)
magician59
Separate the motor from the machine but leave it connected to the wire harness. Protect from any wire-to-metal contace and jump the lid switch. See if the motor will run without a load attached. If it does, attach the pump to it and try it again. if it runs, there's something wrong in the gearcase. Post your results.
Sully04Mike
#3 Posted : Thursday, April 1, 2010 10:00:09 AM(UTC)
Sully04Mike
Thanks for the advise. I disconnected the motor and it still humed. I had to reset it by plugging it in then opening and closing the lid 6 times in 12 seconds. Then it started spinning again. When all checking was done it turned out to be a small sock in the pump. I purchaced a new pump and all is working well. Thank you.
