Hi, i been check the power to the dryer is good,the thermal fuse,the heating element and the thrmst - fix ,the high limit thermostat,the Thermal cut-off are all working. But it just no heat and no power goes to the heating element. Please tell me what do i need to check next?
are you getting 220 volts coming to dryer
Yes, i'm getting 220 volts coming to dryer.
possibly its a timer problem ,part of the circuit to heater goes through timer
Where can i fint it and check it ? Thanks!!!!!!1
