Groups ready for retrieval: Registered
pumps out very slowly,not familiar with pumping system,used to older models. always leaving some waterin bottom of tub. drai solenoid ok no kinks in dran hose nothing in basket. thank you for yor help herman it was great to find your site:confused:
Rank: Administration
Groups: Joined: 7/18/2007(UTC) Posts: 799
Herman, This "new and improved" GE dishwasher is well known for its drain problems. In most cases, piston and nut assembly has to be replaced. Breakdown diagrams: Model GSD5134D00WW - piston and nut kit is number 564 on the tub diagram. If there is an airgap installed at the sink, check to make sure it's not clogged. Hope this helps.
