Wade drow
#1 Posted : Thursday, April 10, 2008 6:55:54 AM(UTC)
Wade drow
Brand new maytag side by side has a vibrating compressor. When you get near it, it quits. I assume this is because I am on a crawl space and the extra weight on the floor near the frig causes a shift in the frig's angle slighty?? I can physically move the frig a bit and the noise goes away. It returns however in a little while.
Do I need to tighten the mounting bolts on the compressor? It is a rather annoying noise.
Also, any reviews on this brand of frig? Good or Bad? This is my first Maytag product.
Any advice is appreciated!!
Wade
#2 Posted : Friday, April 11, 2008 3:05:03 AM(UTC)
Remove back panel and look for vibrating condenser coils or a compressor mount thats loose. If the noise is internal to the compressor, call for warranty repair.
ccj
#3 Posted : Tuesday, April 22, 2008 8:18:44 AM(UTC)
ccj
I have the exact same problem with mine. It is squeezed in the space pretty tightly and I was uncertain if this was contributing to the problem.
#4 Posted : Wednesday, April 23, 2008 1:23:12 AM(UTC)
Tell us if the vibration is an internal compressor rattle, you just remove back panel and check.
