Hello,
I bought a near new LG gas dryer, converted it to Propane and added a side venting kit.
My Problem: No Heat. After the dryer turns on, the Igniter glows (reaches nearly 4 Amp on clamp-meter), then the Propane kicks in and shoots a nice blue torch down the pipe.(for barely 1+ second) Immediatly when the flame is there the Amp. on the Igniter drops down to Zero and the flame dies. I have tested the flame sensor and the 2 Temp sensors near the torch for continuity. This happens with the machine fully assembled and also when I take it apart to get a visual.
Been reading lots here on the Forum , but in most cases there is No Heat at all (instead of a short burst!)
Please help :eek:
Does anybody have any suggestions ??
I am wondering if I should bridge the thermo sensors (1 by 1) to see if the flame stays on ? (disconnect the 2 wires from sensor and clamp/tape together) Is that a good idea to troubleshoot my dryer ?.
Thank You for any input........
I was really hoping that someone here on this forum would be able to give me some advise troubleshooting my dryer.
Maybe my problem is too complicated ?? :confused:
Maybe the troubleshooters here don't sell parts for my LG dryer and they don't see a way to make money of my problem??
My dryer is near new.....bought about a year ago, used for a few weeks and then was put into storage. Lucky for me I found an Appliance Expert who suggested me to gently tap the coils on the gas valve as the plunger might be stuck.
Problem solved!!
