DIY Fireman
#1 Posted : Monday, November 23, 2009 8:54:39 AM(UTC)
DIY Fireman
First off thanks to all of you that contribute to this forum, I have used it and saved $100's in the past year or so fixing mutliple appliance problems. I used it to repair my oven last year
(Whirlpool GBD307PDB09) and am now back with a new problem that I don't see any answers to. Last year I had to to replace both the Oven shut down thermal fuse and the Control Panel Thermal Fuse due to the self cleaning problem with this model. NOW, while the oven was not in use the control panel beeped about 5-6 times and the display went blank; pushing buttons results in beeps but no apparant function. Shut down power and power up results in single beep and then 5-6 beeps approximately 1 minute later. So far I have checked and ruled out:
Control Panel Thermal fuse
Oven shutdown Thermal Fuse
Sister Board (ciruit closed)
Control power transformer is outputing about 2V too high (is the panel that sensative?) the OHMS are also out of range input is supposed to be between 75-95 and is at 58 output is supposed to be <1 and is 2
I am following the directions from a previous post right now, I have unplugged the control panel power ribbon and powered up will plug it all back in, in a few hours to check, but the beeps have already done their thing.
Any suggestions welcomed?
Tom Stockton
#2 Posted : Friday, March 26, 2010 6:57:45 AM(UTC)
Tom Stockton
I am having the exact same problem. After I start the oven, the display goes blank after a few minutes. Push the buttons and it beeps, but does not do anything else. Wait a half hour or so, and the display is back, and oven works fine. It has now done this twice - yesterday and about two months ago. In between, everything was fine. Any ideas on what the problem is?
kray
#3 Posted : Friday, March 26, 2010 11:24:06 AM(UTC)
kray
fellow posters:
Mine and my neighbor's same Built-In Electric Convection Oven (GBD307PDB7) is doing the same thing and mine is completely dark now. Here's some other suggestions from another site: My Built-In Electric Convection Oven (GBD307PDB7) control panel doesn't work. Won't turn oven on, no lights, but still beeps when you push buttons. It went off last week, then came back on as we pushed some buttons. Now, won't come on. Advice?
Submitted: 444 days and 14 hours ago.
Category: Appliance Value: $15 Status: CLOSED +Read More
Answer
im sorry i just saw the model # if your first question. well it sound like the low voltage trans former is bad.
GBD307PDB7 CONTROL PANEL Parts
DIY Fireman
#4 Posted : Friday, March 26, 2010 6:36:55 PM(UTC)
DIY Fireman
Hey all, I ended up replacing the entire control panel, found one with a lifetime warranty for the tune of $161+ change. It fixed my problem and has been working fine since Nov. Hope that helps.:)
Originally Posted by: kray Go to Quoted Post
fellow posters:
Answer
B Walsh
#5 Posted : Thursday, December 12, 2013 8:40:44 PM(UTC)
B Walsh
Could you tell me where you bought a control panel for under $200? With a lifetime warranty (I would LOVE to have that) I am having the same problem everyone else is. I think it is horrible that these electronic advances are causing perfectly good appliances to be trashed. Give me the stone age mechanics! They did not obsolesce after 5 years...Anyway, I would be very grateful if someone could help me avoid buying another oven...thank you!
ljoulakh
#6 Posted : Thursday, December 19, 2013 12:48:58 PM(UTC)
ljoulakh
my oven went dead, clock disapeared from display panel. there is beeps only when i click on any bottom but no fix to the issue.
i turned the circuit off for few minutes but that didn't solve this issue.
can someone help please:
is there any dignostic that i have to do or just replace control panel?
dacjordan
#7 Posted : Tuesday, December 31, 2013 3:39:45 AM(UTC)
dacjordan
I turn the oven on and in less than 5 minutes it will beep a few times and then the display is gone maybe 30min - hour it will come back on and work fine how do I fix this
eddieharo
#8 Posted : Thursday, October 30, 2014 5:44:23 PM(UTC)
eddieharo
Hey, Thanks for the post.
I have the same problem, and ordered the part, for $183 + SH.
I am wondering if there is a video on how to open the board assembly without cracking any parts.
My double stacked oven model number is RBD245PDS14
Any ideas would help!
Greatly appreciate your inputs!
Thanks!
Guest
#9 Posted : Friday, September 29, 2023 5:03:14 PM(UTC)
Guest
Rank: Guest
United States
Is the only way to replace control panel?
Guest (4)
