sgwynn
#1 Posted : Tuesday, March 23, 2010 8:17:26 AM(UTC)
sgwynn
Greetings all and thanks for this great forum! I had one of the wires going to the heating element get burned and I need to replace the terminal end. It is a female quick connect end that is larger than the standard .250 spade. I cannot find this anywhere. Any ideas ?
Thanks for the help!
magician59
#2 Posted : Tuesday, March 23, 2010 8:29:54 AM(UTC)
magician59
Try 5/16 inch.
#3 Posted : Wednesday, March 24, 2010 2:07:35 AM(UTC)
The following is for a LE5800XSW0
Part number: AP3134638
Look up your unit and you may be able to find in your unit's heater section.
sgwynn
#4 Posted : Wednesday, March 24, 2010 5:29:15 AM(UTC)
sgwynn
Thanks. That should help because I cannot find the right size terminal !
