Greetings all and thanks for this great forum! I had one of the wires going to the heating element get burned and I need to replace the terminal end. It is a female quick connect end that is larger than the standard .250 spade. I cannot find this anywhere. Any ideas ?
Thanks for the help!
The following is for a LE5800XSW0 Part number: AP3134638
Look up your unit and you may be able to find in your unit's heater section. |
THIS FORUM IS DEAD!!!!!!! |
Thanks. That should help because I cannot find the right size terminal !
