nrabey
#1 Posted : Monday, March 22, 2010 10:41:47 AM(UTC)
nrabey
On a Maytag dishwasher I have replaced the leaking drain line but when I pull up the door it feels like the pivots are misplaced and the door is too low to latch.
If I pull the door up the top latches but the lower part of the door is not moving close enough to the main part of the dishwasher to seal.
Any ideas?
Thanks,
Noel
#2 Posted : Tuesday, March 23, 2010 1:31:05 AM(UTC)
Replacement parts for MAYTAG DWU9200ABX Dishwasher - Undercounter | AppliancePartsPros.com
Hard to say what has happened without being there but perhaps the following will help
http://www.servicematters.com/maytag_library/docs/16007823.pdf
nrabey
#3 Posted : Tuesday, March 23, 2010 8:58:33 PM(UTC)
nrabey
Originally Posted by: denman Go to Quoted Post
http://www.servicematters.com/m...ibrary/docs/16007823.pdf
I really appreciate the help
Noel
nrabey
#4 Posted : Sunday, May 9, 2010 3:24:51 PM(UTC)
nrabey
Noel
Thanks very much for the help. It turned out the left hinge was bent and the door latch could not seat properly causing the leak.
There turned out to be more problems and I fixed them all with the help Denman provided and it is working fine now.
Thanks again Denman for all your help.
Noel
nrabey
#5 Posted : Sunday, May 9, 2010 3:31:13 PM(UTC)
nrabey
Noel
Sorry for the delayed thanks. This was my first posting and I just got the email about replying when I posted a washer issue.
I really did appreciate the help and the manual was invaluable.
All the Best,
Noel
Guest (4)
