Water is leaking from ceiling top of fridg. from possible two different vent type area's. Leaks very slow but seems consistent to the point that it gathers at bottom of fridg. as well as upper shelve. Can the panel on top come off for cleaning? unclogging? or ?
Alcon
You might have a restricted defrost drain. I would want to pull the freezer evaporator cover (#16) and the freezer floor cover (#25) out. and check for ice build up. There’s a good chance you will find ice underneath the freezer floor cover.
