geneawho
#1 Posted : Saturday, March 20, 2010 9:55:59 AM(UTC)
geneawho
My maytag operates fine till it reaches the very last rinse and spin. At that time it doesn't spin out until I manually advance the selector dial to spin. This only occurs in the LAST spin. I've experimented by selecting a large load, regular load and hand wash load. In every situation I had to manually advance the selector dial to 'spin'.
I'm unemployed and really need to cut the chase to find out what part it is I need to replace and do it myself. I"ve learned in the past if I don't take care of it when it happens it turns into a bigger more costly situation eventually.
Any suggestions?
Thanks in advance!
magician59
#2 Posted : Saturday, March 20, 2010 2:22:07 PM(UTC)
magician59
Try it in all the other cycles. It could be either a faulty "Extra Rinse" selector switch, or a bad timer.
geneawho
#3 Posted : Saturday, March 20, 2010 4:45:48 PM(UTC)
geneawho
I did try it in all the other cycles and had the same result of my having to manually advance the selector dial to "spin"
Maytag Performance Dishwaher (Dishwasher Repair)
by hager12 3/18/2024 11:34:48 AM(UTC)
Maytag Performa gives up when trying to spin the drum (Washer Repair)
by odetobob 11/10/2020 2:23:13 PM(UTC)
Maytag performa washer won't spin. It drains and i can hear the motor but tub appears stuck. (Washer Repair)
by Brittrepairs 12/21/2019 7:47:28 PM(UTC)
Maytag performa wont heat up (Dryer Repair)
by gr8filed 4/22/2018 8:41:56 AM(UTC)
Maytag Performa Portable Dishwasher Not Getting Power (Dishwasher Repair)
by Mitchewr 5/9/2015 10:30:33 AM(UTC)
Maytag Performa heats on one cycle, not others (Dryer Repair)
by Maytag2015 2/7/2015 6:14:51 PM(UTC)
Maytag Performa filling in middle of wash cycle (Washer Repair)
by oZo61 9/22/2014 4:04:31 PM(UTC)
Maytag Performa Range - Oven / Stove top not working (Oven Repair (including Ranges and Cooktops))
by jh109052 5/4/2014 10:14:08 AM(UTC)
Maytag Performa washer fills, drains, spins, but doesn't agitate (Washer Repair)
by shshimo 3/9/2014 8:25:14 PM(UTC)
Maytag Performa Gas Dryer Timer (Dryer Repair)
by mquinn25@gmail.com 11/28/2013 10:32:54 AM(UTC)
Maytag Performa dryer not running (Dryer Repair)
by bluex 9/19/2013 12:11:15 PM(UTC)
Maytag Performa loud squealing noise (Washer Repair)
by jeneerik 4/27/2013 12:49:18 PM(UTC)
Maytag Performa Top load (Washer Repair)
by dp2763 2/22/2013 2:31:29 PM(UTC)
Maytag Performa Washer loug banging noise when stopping (Washer Repair)
by johncher 2/9/2013 2:43:39 PM(UTC)
Maytag Performa Washer Smoking (Washer Repair)
by Fixineer 1/31/2013 10:22:01 PM(UTC)
