booger32
#1 Posted : Friday, March 19, 2010 7:27:17 PM(UTC)
booger32
Help! Need advice. Last week the frige stopped cooling but the little condensor fan in the bottom rear was still running. Was suggested that it may be the defrost timer so I replaced it. I had the frige unplugged for 3 days prior to changing the timer. Once I replaced it, plugged in the frige, it ran perfectly. Compressor started and stopped just like normal for about 3 days and all was well.. And then...I found the frige warming up on the inside, the little fan in the rear running continously and everything thawing out.
This Kenmore has a tecumseh compressor and a tech told me today, over the phone, that the compressor was shot. Could it maybe be just the (PTC) start relay on the compressor?
Oh yea...one more thing. When the compressor decided to stop running the first time, the water on the front door wouldn't work. When I replaced the defrost timer and got the frige running, the water started working. Coincidence?
Thanks, Steve
Chattanooga
kayakcrzy
#2 Posted : Saturday, March 20, 2010 3:51:40 AM(UTC)
kayakcrzy
Thanks, Steve
Chattanooga
About the water in the front door not working, suggest that the fan in the freezer might not be running, because the water in the tank in the refrigerator is frozen. The compressor could be cutting off, because it is getting hot, because the fan is not running in the freezer. Tom ApplianceEducator.com - Parts
#3 Posted : Saturday, March 20, 2010 4:07:09 AM(UTC)
[COLOR="Blue"]This Kenmore has a tecumseh compressor and a tech told me today, over the phone, that the compressor was shot.[/COLOR]
Do not know how the tech came to that conclusion unless you gave them more info than given here.
[COLOR="Blue"]Could it maybe be just the (PTC) start relay on the compressor?[/COLOR]
Yes
Here are a couple a good sites with fridge repair info.
Refrigerator Repair Guide: How To Fix a Refrigerator - ACME HOW TO.com
http://www.applianceaid.com/frig.html
First you have to determine if the compressor is running.
It should be warm and you should be able to hear/feel it vibrating.
If it is not running then it may be a starter problem or a compressor going bad.
If it is running then you may have a defrost problem.
First remove the evaporator cover in the freezer so you can see the coils.
Not do not let them de-ice.
If they are heavily iced/frosted over you have a defrost problem.
If yes.
Manually force a defrost cycle by turning the defrost timer cam (Item in Section ) till the fans and compressor turn off.
Now check the defrost heater to see if it is on.
Be careful you do not want to burn your fingers.
If the heater is on then the timer needs replacing, re: it is probably stalling during it's rotation so is never getting into a defrost cycle.
If not on.
Unplug the unit.
Remove the wire for one side of the heating element (Item in Section ) from the wiring and measure it for continuity, usually around 20 ohms or so.
If the heater is OK
Remove one wire to the defrost thermostat (Item in Section ) and measure it, should be 0 ohms when frozen. Note that it opens just above freezing so must be frozen to check it. Also inspect it, if it is bulged at all replace it even if it measures OK.
If both the above are OK then odds are the defrost timer contacts are toast.
Best way to test this is a live test to see if you have 120 volts across the heater/defrost thermostat combo.
Kenmore side by side not cooling (Refrigerator & Freezer Repair)
by keller69 5/14/2012 9:46:20 AM(UTC)
by REAPHOTO 12/29/2010 6:39:14 AM(UTC)
Kenmore Side by side not cooling (Refrigerator & Freezer Repair)
by bkeenom 11/2/2010 7:44:55 AM(UTC)
Kenmore side by side not cooling or freezing (Refrigerator & Freezer Repair)
by williebones 10/17/2010 8:32:44 AM(UTC)
