john6109
#1 Posted : Friday, March 19, 2010 9:47:31 AM(UTC)
john6109
The circulator failed on my 5-6 yr old bosck dishwasher. I ordered a new pump and tried replacing it, I got 99% of the way through and then broke the tab on the plastic base plate of the pump that keeps the motor from turning too far relative to the motor. I just ordered a mew base plate - any suggestions on how to remove the bad pump base and install the new? There does not seem to be any obvious way that it comes apart.
#2 Posted : Friday, March 19, 2010 2:41:35 PM(UTC)
The instructions are attached to the reply.
Here are the breakdown diagrams and Replacement parts for Bosch SHV46C03 UC/14 (FD 8211-) | AppliancePartsPros.com
File Attachment(s):
Circulation Pump and Motor assembly.doc (909kb) downloaded 16 time(s).
john6109
#3 Posted : Friday, March 19, 2010 4:16:11 PM(UTC)
john6109
Thanks, this looks like just what I need - (If only I had posted on the forum before my first attempt...)
#4 Posted : Friday, March 19, 2010 7:15:15 PM(UTC)
