LUISETO
#1 Posted : Thursday, March 18, 2010 10:33:47 AM(UTC)
LUISETO
Can Only Hear A Fan Going/ Moves Air/room Temperature Nothing Is Actually Cooling Any Where. Both Freezer Part And Refrigerator ?
magician59
#2 Posted : Thursday, March 18, 2010 12:04:05 PM(UTC)
magician59
Unplug it; wait about a minute; then plug it back in and tell us if you hear the compressor start up. I should sound like sort of a mechanical "purring".
LUISETO
#3 Posted : Thursday, March 18, 2010 1:03:57 PM(UTC)
LUISETO
No.not A Sound From It At All
LUISETO
#4 Posted : Thursday, March 18, 2010 1:08:13 PM(UTC)
LUISETO
No.not A Sound From It At All. Tried Several Times,nothing At All
magician59
#5 Posted : Thursday, March 18, 2010 1:20:19 PM(UTC)
magician59
Three possibilities: Dead compressor; bad relay/overload (the plastic parts connected to the compressor); or a bad control board. How handy are you at using a multi-meter?
LUISETO
#6 Posted : Thursday, March 18, 2010 4:19:37 PM(UTC)
LUISETO
Dont Have One But I Think I'll Be Ok. Can You Tell Me What To Do?
magician59
#7 Posted : Thursday, March 18, 2010 6:37:43 PM(UTC)
magician59
Unplug the machine again, and remove the plastic assembly attached to the compressor. Shake the larger of the two components. If it rattles, replace it. While you're at it, set your meter to the lowest ohms scale. You'll see the pin connectors on the compressor where the relay/overload were attached. they form a triangle, with one pin at the apex (either pointing up, or down). The apex is the common terminal. It represents the connection that is connected to one end of both the windings inside. Place one test probe on the common, and the other probe on one of the other pins. Record the reading. Now place the second prob on the other pin and record that reading. Then remove the probe from the common terminal and place it on the other pin, so that you're reading between the pins that form the base of the triangle. If the compressor is good, the third reading should be roughly the sum of the other two. Finally, test for continuity (any positive reading in the lowest ohms range) between each pin terminal on the compressor, and chassis ground. If any one of the terminals has continuity to ground, the compressor is bad. Let us know what you find.
weeks252010
#8 Posted : Thursday, June 30, 2011 2:02:16 PM(UTC)
weeks252010
Hello, I have the same problem, however, i DO hear the "purring" noise you mentioned to be the compressor. What could be the problem? I have the GE model 20 side by side with icemaker. Freezer and fridge are room temp. Got home from work yesterday and couldn't make dinner for the kids because most of the food went bad. Could anybody PLEASE help me
LG Refrigerator not cooling or freezing (Refrigerator & Freezer Repair)
by jesliu88 1/23/2021 8:44:04 PM(UTC)
GE GSH25JSDDSS Not cooling or Freezing (Refrigerator & Freezer Repair)
by wag357 11/2/2019 10:24:52 AM(UTC)
Samsung not cooling or freezing (Refrigerator & Freezer Repair)
by PhillipsHouse 1/17/2016 7:11:23 PM(UTC)
Amana Refrigerator/Freezer Not Cooling or Freezing (Refrigerator & Freezer Repair)
by willie1280 5/27/2015 10:24:46 AM(UTC)
Not cooling or freezing (Refrigerator & Freezer Repair)
by cdgal63 8/13/2014 6:49:14 AM(UTC)
by booie 1/31/2014 7:10:20 AM(UTC)
Whirlpool SBS not cooling or freezing (Refrigerator & Freezer Repair)
by Alysia111 7/21/2013 6:54:49 AM(UTC)
fridge, freezer not cooling or freezing (Refrigerator & Freezer Repair)
by tripper 6/16/2013 4:59:40 AM(UTC)
Frigidaire refrigerator not cooling or freezing (Refrigerator & Freezer Repair)
by mrsmobley 6/10/2013 7:37:50 PM(UTC)
by carmonafam 3/31/2013 11:12:19 PM(UTC)
GE Refrigerator/freezer not cooling or freezing (Refrigerator & Freezer Repair)
by n4moe 11/17/2012 11:44:40 AM(UTC)
Frigidaire Refrigerator not cooling or freezing (Refrigerator & Freezer Repair)
by cca610 11/5/2012 2:01:36 PM(UTC)
Kenmore Fridge not cooling or freezing (Refrigerator & Freezer Repair)
by seayii 7/23/2012 10:30:25 AM(UTC)
GE Profile Arctica Refrigerator Not Cooling or Freezing But Running (Refrigerator & Freezer Repair)
by mGalicia 5/29/2012 3:15:30 AM(UTC)
GE side by side fridge/freezer not cooling or freezing (Refrigerator & Freezer Repair)
by Lou7 4/23/2012 8:36:19 PM(UTC)
