bill-JupiterFla
#1 Posted : 15 years ago
bill-JupiterFla
We just put in a new timer and the dryer cycle still doesn't turn off. Is there a way to test the new timer? Is there any other related part that can be affecting the timer?
magician59
#2 Posted : 15 years ago
magician59
Does this happen in all the drying cycles?
bill-JupiterFla
#3 Posted : 15 years ago
bill-JupiterFla
Not sure about ALL cycles................I will try that. What would it suggest if not all cycles? or if ALL cycles?
magician59
#4 Posted : 15 years ago
magician59
If it happens only in one or more cycles, but operates in at least one cycle, that would point to a bad timer.
bill-JupiterFla
#5 Posted : 15 years ago
bill-JupiterFla
I tried all the different cycles............none of them work AND it is a brand new timer. Any other ideas?
magician59
#6 Posted : 15 years ago
magician59
What do you have to do to get it to stop?
bill-JupiterFla
#7 Posted : 15 years ago
bill-JupiterFla
To stop it, I turn it to the off position....................or open the door.
bill-JupiterFla
#8 Posted : 15 years ago
bill-JupiterFla
In other words the dial does not turn unless manually moved.
magician59
#9 Posted : 15 years ago
magician59
Either you have a bad timer, or the dial is blocked in some way.
