2 Pages<12
Fastlanedan
#11 Posted : Tuesday, March 16, 2010 9:13:57 AM(UTC)
Fastlanedan
Hi Hill, you are probably right. most of the carrier unit I've work on with the symtom he describe are the 10 ton unit. Thats why i need to know the model #,
jeffrey_benjamin
#12 Posted : Wednesday, March 17, 2010 11:42:00 AM(UTC)
jeffrey_benjamin
Finally we replaced the evaporator section and all is well now suction pressure 69psig with high side @260psig. This unit cools a shopping mall top floor. We suspect the coil was too blocked up even after cleaning. apparently after not being serviced for over 2-3 yrs all that mock etc., could not be cleaned out . Thanks to u all for your advice, we will let u all know how it goes. jeffrey_benjamin. :) ;)
hvac_hillbilly
#13 Posted : Friday, March 19, 2010 2:43:26 PM(UTC)
hvac_hillbilly
thanks now i can believe it is a 30 ton if your cooling a entire floor af shopping center
Guest (5)
2 Pages<12
