rickado
#1 Posted : Tuesday, April 15, 2008 10:48:12 AM(UTC)
rickado
I Have no water supply to the ice maker. The power is on to the paddles because they are turning but no power at the electrical plug at the dual water inlet value.Could the thermosat be bad. Thanks rickado
gearhead1218
#2 Posted : Tuesday, April 15, 2008 6:10:39 PM(UTC)
gearhead1218
What I do with the dual valves is to temporarily swap the wiring on the coils on the inlet valve. Then depress the water lever in the door. If the ice maker fills up then the valve is good. If that's the case then the ice maker would need replacement. If no water, then the valve would be the culprit.
Just remember to swap the wiring back.
rickado
#3 Posted : Wednesday, April 16, 2008 7:44:42 AM(UTC)
rickado
THANKS GEARHEAD value works when I swithed wires. I ordered a new ice maker. Thanks rickado
gearhead1218
#4 Posted : Wednesday, April 16, 2008 12:01:06 PM(UTC)
gearhead1218
Glad I could help.
Check back and let everyone know how you made out.
rickado
#5 Posted : Saturday, April 19, 2008 6:02:07 AM(UTC)
rickado
Thanks GEARHEAD new ice maker works great. rickado
gearhead1218
#6 Posted : Saturday, April 19, 2008 7:25:26 AM(UTC)
gearhead1218
Very good.
Guest (5)
LG LDC24370ST Ice Maker Issues (Refrigerator & Freezer Repair)
by Guest 6/29/2024 8:55:44 AM(UTC)
Mysterious leak -Top Freezer w/Ice maker (Refrigerator & Freezer Repair)
by St.B 6/18/2024 8:40:52 AM(UTC)
Water Runs Too Long - Ice maker (Refrigerator & Freezer Repair)
by shfdyoung 6/11/2024 3:01:06 PM(UTC)
Bosch Ice Maker Dropping Ice Once Week (Refrigerator & Freezer Repair)
by Guest 5/31/2024 1:40:51 PM(UTC)
Lg ice maker leaking (Refrigerator & Freezer Repair)
by Guest 4/10/2024 2:58:55 PM(UTC)
KITCHEN AID UNDERCOUNTER ICE MAKER KUIC18NNZS0 (Refrigerator & Freezer Repair)
by kwhowell6539 3/25/2024 1:49:40 PM(UTC)
Ice maker slabbing (Refrigerator & Freezer Repair)
by Guest 3/11/2024 8:34:02 PM(UTC)
Frigidaire Freezer FPFU19F8WF4 - ice maker problem (Refrigerator & Freezer Repair)
by Eric8888 3/5/2024 11:02:19 AM(UTC)
Installing ice maker, looking for holes (Refrigerator & Freezer Repair)
by Grendel25 2/16/2024 10:02:12 AM(UTC)
ice maker in LG fridge model #LFX31925st/08 (Dishwasher Repair)
by diohabla 2/16/2024 8:36:50 AM(UTC)
Freezer holding at 22 degrees and ice maker (located in refrigerator cabin) isn't working (Refrigerator & Freezer Repair)
by eric5605 2/13/2024 4:35:48 AM(UTC)
Ice maker fiil/dump (Refrigerator & Freezer Repair)
by Guest 2/12/2024 5:46:50 AM(UTC)
GE Fridge GFE28GMKJES Ice Maker Not Working (Refrigerator & Freezer Repair)
by aopenshaw 2/9/2024 8:35:22 AM(UTC)
Ice maker issues and more? LG LFX25971 (Refrigerator & Freezer Repair)
by turtlejay 2/1/2024 5:07:00 PM(UTC)
LG French Door can the lower craft ice maker be swapped to cubed? (Refrigerator & Freezer Repair)
by Bstewart63 1/3/2024 11:45:50 AM(UTC)
