2 Pages12>
rtbme
#1 Posted : Friday, March 12, 2010 2:38:29 PM(UTC)
rtbme
whirlpool duet washer:LAST LOAD EVERYTHING WAS FINE. NEW LOAD, MACHINE LITES TURN ON, CYCLE LITE BLINKS WHILE ALL OTHERS APPEAR NORMAL. DOOR IS CLOSED. WHEN WE PUSH THE START BUTTON, NOTHING HAPPENS REGARDLESS OF CYCLE SELECTED. WE DO NOT HEAR THE DOOR LOCK ENGAGE. machine wont run the dia test, cycle light just flashes in every location ie: heavy-light-whites-rinse etc.
Any ideas? I'm able to tear this thing apart, I 'd like a direction to start.
Thanks RT
#2 Posted : Friday, March 12, 2010 4:58:50 PM(UTC)
The first thing I would do is unplug the washer for a few minutes and then plug it back. Sometime it helps to eliminate the problem.
rtbme
#3 Posted : Saturday, March 13, 2010 5:48:36 AM(UTC)
rtbme
ya, i tried that w/ no results. There has to be some explanation or test to hone in on the problem. Thank you for the reply, hopefuly someone has an answer here. Anyone? Chime in here, laundry is building up!
RT
#4 Posted : Sunday, March 14, 2010 4:20:17 AM(UTC)
Let us know if you have a meter to check things.
rtbme
#5 Posted : Sunday, March 14, 2010 5:27:12 AM(UTC)
rtbme
yes I have a meter to test what ever you suggest.
RT
#6 Posted : Sunday, March 14, 2010 6:19:13 AM(UTC)
You can download the Whirlpool front load washer job aid at web site appliancejunk.com , click on Whirlpool washers, then on the front loader.
Sorry, I'm not the computer whiz that Sidfink43 is, best I can do for you.
Seems like a door switch problem. You can look at the handy control module pin breakout for all the interfacing wiring such as the door switches.You can acess the service sheet behind the bottom front panel. This might steer you to a bad control module.
Good luck.
#7 Posted : Sunday, March 14, 2010 1:29:38 PM(UTC)
Here is the Tech sheet.
Here is the Service manual.
Here are the breakdown diagrams and Replacement parts for WHIRLPOOL GHW9100LQ0 | AppliancePartsPros.com
rtbme
#8 Posted : Monday, March 15, 2010 10:08:39 AM(UTC)
rtbme
Thanks for the help, I'll take a look tonight w/ this info to see whats up.
RT
rtbme
#9 Posted : Friday, March 19, 2010 6:32:07 PM(UTC)
rtbme
The CCU does not make any click or sounds at all when I power up the machine. Fundamentaly does this indicate the CCU is bad? I'm thinking this is the culprit, not the door switch.
#10 Posted : Friday, March 19, 2010 7:25:06 PM(UTC)
Originally Posted by: rtbme Go to Quoted Post
...The CCU does not make any click or sounds at all when I power up the machine...
Your statement is correct. According to the Tech sheet this is a sign of bad CCU.
- The CCU Part number: AP3767528
2 Pages12>
