Gr8ful
#1 Posted : Friday, March 12, 2010 4:43:55 PM(UTC)
Gr8ful
Since second checking of the circuits. I have found that the start button doesn't seem to be responding to the start. I'm still not sure what to do. I don't want to throw good money into bad...
#2 Posted : Saturday, March 13, 2010 12:51:06 AM(UTC)
Gr8ful
I noticed you have another post/thread saying you replaced the timer.
Please just use "POST REPLY" so there is just one thread otherwise it will get confusing.
More info on how you checked for power would be usefull re: where your meter leads were.
Here is the wiring diagram.
http://manuals.frigidaire.com/prodinfo_pdf/Webster/131850300.pdf
Best to unplug the unit and check the components in the start circuit using resistance, also the safest. Could be the thermal fuse Item 36 in Section 1.
I am assuming that you can hear the timer running only when the start switch is pushed. If this is true that you know the switch is OK.
If it is blown get back to us as there are things you should check as to what caused it to blow.
White Westinghouse stackable Washer'Dryer Shrieks & doesnt dry (Dryer Repair)
by Morton60 1/5/2020 10:23:34 AM(UTC)
Hansen White Westinghouse Washer (Washer Repair)
by DNLDHNSN 2/20/2013 1:39:56 PM(UTC)
white westinghouse ref (Refrigerator & Freezer Repair)
by Gina sexton 11/13/2012 11:18:44 AM(UTC)
White Westinghouse Spacemate SM 2300L (Washer Repair)
by sherryLynn313 6/14/2011 9:14:16 AM(UTC)
White Westinghouse appliance co. (Dryer Repair)
by Dean Andrews 3/28/2011 2:22:42 AM(UTC)
White Westinghouse Dishwasher will not drain (Dishwasher Repair)
by Guardian305 10/1/2010 11:38:11 AM(UTC)
white westinghouse washer belt replacement (Washer Repair)
by Kmcduffie 4/13/2010 11:34:26 AM(UTC)
White Westinghouse Dryer (Dryer Repair)
by Gr8ful 3/12/2010 11:22:09 AM(UTC)
White Westinghouse Washer won't drain and has burnt rubber smell (Washer Repair)
by brandiannh 11/24/2009 9:35:02 AM(UTC)
White Westinghouse Spacemate (Washer Repair)
by dorothea 9/7/2009 8:13:51 PM(UTC)
white westinghouse 2 speed (Washer Repair)
by washing momma blues 12/14/2008 7:02:37 AM(UTC)
White Westinghouse dryer hums loud when drying (Dryer Repair)
by thomass_72 12/8/2008 12:37:45 PM(UTC)
Please Help.....White Westinghouse Spacemates (Dryer Repair)
by oceanmaid 9/4/2008 4:11:53 PM(UTC)
White Westinghouse washer won't spin (Washer Repair)
by help_me_please 9/17/2007 9:13:14 AM(UTC)
