chickchick
#1 Posted : Wednesday, March 10, 2010 11:35:43 AM(UTC)
chickchick
My electric dryer has 4 drying settings: Extra Low, Low, Med, High. The low setting is not drying completely. Other settings work ok. Lint not a problem.
sidfink43
#2 Posted : Thursday, March 11, 2010 3:18:18 PM(UTC)
sidfink43
I understand you say lint is not a problem, but does this mean you have cleaned out both the vent to the outside and the lint chute? The lint chute in these machines can get very clogged over time, so it is important to keep it clear.
If air flow is sufficient it may be that you heating element is too weak to dry at the lowest setting.
chickchick
#3 Posted : Saturday, March 13, 2010 7:11:06 AM(UTC)
chickchick
Thanks sidfink43, you were right, the vent pipe to the outside had the start of a buildup deep inside from a mouse or chipmunk bringing in pine needles, nuts & grass. I cleaned it and put a big enough screen to keep animals from getting in but allowing lint to flow out. Thakn you again.
sidfink43
#4 Posted : Saturday, March 13, 2010 3:02:53 PM(UTC)
sidfink43
Great, glad you found that and that it was a cost free fix (we really like those)
Good luck and thanks for the update.
