cbrown35
#1 Posted : Thursday, March 11, 2010 9:38:58 AM(UTC)
cbrown35
I tried to defrost the frreezer section and as I was removing the ice from the freezer, something got punctured and the freon starting dripping out. Which cause the frigerator to go out. Is it anyway it can be fixed or does it have to be replaced. It was made in Nov. 1985.
magician59
#2 Posted : Thursday, March 11, 2010 9:57:13 AM(UTC)
magician59
A repair depends on how big the puncture is. The material is aluminum. It may require the replacement of the evaporator. This will be very costly.
#3 Posted : Thursday, March 11, 2010 3:25:36 PM(UTC)
If you failed to unplug the fridg when the punture happened, the compressor has sucked in water and is now unrepairable.
#4 Posted : Friday, March 12, 2010 12:52:14 AM(UTC)
Replacement parts for General Electric SSD4CGB Refrigerator | AppliancePartsPros.com
Often "Requires special attention" means obsolete.
In any case you would need a pro to fix it and it is not worth putting the dollars into it.
I would buy a new unit.
