Pamela Post
#1 Posted : Tuesday, March 9, 2010 10:20:25 AM(UTC)
Pamela Post
My Kenmore dryer won't start. Press button and nothing happens. Checked power to outlet - fine. The timer seems to be working - can hear it ticking. The dryer door connection seems ok. Any suggestions?
bizkid23
#2 Posted : Tuesday, March 9, 2010 6:05:08 PM(UTC)
bizkid23
Groups: Expert
Hello,
There are several things that can cause this but the most common are either the start switch or door switch. Check these first and let us know.
Pamela Post
#3 Posted : Tuesday, March 9, 2010 9:08:10 PM(UTC)
Pamela Post
Originally Posted by: bizkid23 Go to Quoted Post
Hello,
OK, but how exactly do I check them to make sure they are in good working order?
#4 Posted : Wednesday, March 10, 2010 4:01:31 AM(UTC)
Here is a good site with basic dryer repair help
http://www.applianceaid.com/whirlpool-dryers.html
Switches etc. are best checked with a meter. It will let you check things with the unit unplugged which is the safest. Note that 240 volts in a dryer is lethal.
I cannot find tech info on this unit but was able to get some parts info off the Sears parts site so am basing the following on that.
Check inside the control console for the wiring diagram they like putting it in there.
Another thing you may want to check is the thermal fuse on the blower wheel.
Unplug the unit and check the fuse with a meter should be 0 ohms.
Jiggery Pokery method is.
Unplug the unit.
Remove both wires from the fuse, short them together and tape them up so they will not short to the frame.
Plug the unit in and give it a try.
If blown, replace the fuse ASAP as it is a critical safety device re: prevents lint fires which can turn into house fires.
Also clean/check your vent system and the blower as these are the most common causes of it blowing.
Kenmore Elite dryer won't start (Dryer Repair)
by Guest 6/22/2024 6:34:42 AM(UTC)
LG DLEX5170V electric dryer won't start (Dryer Repair)
by Guest 2/23/2024 11:17:20 AM(UTC)
Dryer won't start after changing fuses and timer (Dryer Repair)
by Guest 1/17/2023 11:21:44 AM(UTC)
Dryer Won't start - Repair Video (Dryer Repair)
by Guest 8/8/2021 1:55:18 PM(UTC)
Kenmore 100 Series Dryer Won't Start (Dryer Repair)
by juser 11/7/2020 4:44:16 PM(UTC)
Gas dryer won't start at all (Dryer Repair)
by GuyGreg 2/21/2018 2:26:33 PM(UTC)
Dryer won't start (Dryer Repair)
by Ginadrc 1/26/2018 7:24:30 PM(UTC)
by Petem 12/2/2017 3:27:50 PM(UTC)
Maytag dryer won't start (Dryer Repair)
by eagle243 11/15/2017 6:44:39 PM(UTC)
Dryer won't start after replacing the heating element (Dryer Repair)
by ivyholly 6/8/2017 6:45:42 PM(UTC)
Dryer Won't Start-Lights Blinking (Dryer Repair)
by rleigh 6/5/2017 9:20:31 AM(UTC)
Inglis dryer won't start (Dryer Repair)
by jkeefe 4/20/2017 2:48:09 AM(UTC)
Amana Dryer won't start, but still gets hot (Dryer Repair)
by halfmoonranch 3/15/2017 9:38:33 AM(UTC)
Dryer won't start (mid-troubleshooting, could use some help) (Dryer Repair)
by OUberLord 3/13/2017 7:15:55 PM(UTC)
Whirlpool Dryer Won't Start (Dryer Repair)
by agjr200hp 2/5/2017 5:36:21 AM(UTC)
