doomee
#1 Posted : Monday, March 8, 2010 5:12:42 PM(UTC)
doomee
Dryer gets hot but not tumbling ?
#2 Posted : Tuesday, March 9, 2010 12:25:20 AM(UTC)
Part Details - WHIRLPOOL Motor switch, dryer, part number: AP2975202
More info on the problem would be useful.
Sounds like your belt is broken.
The motor has a centrifugal switch on it. This switch closes when the motor gets close to operating speed. Since you have heat the motor must be running.
Could be that there is a switch problem but more likely the above.
doomee
#3 Posted : Tuesday, March 9, 2010 5:45:23 AM(UTC)
doomee
Originally Posted by: denman Go to Quoted Post
I will take it apart this morning just in case how do u test the motor switch and or the motor itself?
