Julierob
#1 Posted : Sunday, April 13, 2008 3:54:28 PM(UTC)
Julierob
Our Dryer wont turn, When you push the start button nothing happens. Do you have any advice. Thanks
gearhead1218
#2 Posted : Sunday, April 13, 2008 4:51:58 PM(UTC)
gearhead1218
Could be a few things.
1. Have you got 220 volts?
2. If you have proper voltage check your door switch for continuity. If the switch doesn't close the circuit when the door is closed the dryer won't work.
3. Check your thermal fuse for continuity. Should have continuity, if not replace it.
If it's not one of those three things, check back.
Julierob
#3 Posted : Sunday, April 13, 2008 5:48:24 PM(UTC)
Julierob
hey gearhead 1218
thanks for your advice--but no go. We have 220. I am quite green so dont understand the concept of "continuity". I have located the thermal fuse but again dont grasp how i would properly check for continuity. thanks!
gearhead1218
#4 Posted : Monday, April 14, 2008 2:40:27 AM(UTC)
gearhead1218
If you're not versed on the operation of an electrical multi-tester then my advice would be to get a pro in to service the unit.
LG Dryer wont turn on (Dryer Repair)
by stz2 7/28/2021 2:09:54 AM(UTC)
Kenmore Dryer Wont Turn On (Dryer Repair)
by tmurphy12 11/11/2017 5:37:21 PM(UTC)
Dryer wont turn on. Nothing at all (Dryer Repair)
by jim5775 2/7/2013 1:31:10 PM(UTC)
Dryer wont turn on, bulb stays on when door closed (Dryer Repair)
by mazw 7/24/2012 4:21:01 PM(UTC)
Dryer wont turn on, bulb stays lit when door closed (Dryer Repair)
by mazw 7/24/2012 4:13:34 PM(UTC)
by sweetness 6/21/2012 12:24:11 PM(UTC)
admiral dryer wont turn on (Dryer Repair)
by tammy27 6/12/2012 1:08:36 PM(UTC)
by G.A.Russell 2/12/2012 12:42:26 PM(UTC)
by blackcobra427 11/2/2011 9:31:12 AM(UTC)
Roper Dryer wont turn on (Dryer Repair)
by edwardsnl 1/15/2011 12:37:58 PM(UTC)
by snooki 12/2/2010 5:45:01 PM(UTC)
by ritadi 7/4/2010 9:30:53 AM(UTC)
by carri0321 3/29/2010 1:34:12 PM(UTC)
lady kenmore ultra fabric care electric dryer wont turn on (Dryer Repair)
by John414 3/6/2010 7:19:25 AM(UTC)
Frigidaire dryer wont turn on (Dryer Repair)
by gamermom79 1/13/2010 11:15:41 AM(UTC)
