peachy
#1 Posted : Monday, March 8, 2010 9:04:20 PM(UTC)
peachy
I have water collecting in the bottom of my refridgerator on the freezer door side , it freezes there and leaks out onto the floor
#2 Posted : Tuesday, March 9, 2010 1:43:28 AM(UTC)
Replacement parts for FRS24XHA models | AppliancePartsPros.com
Here is a manual which may be close to your unit
http://frigidaireservicetips.com/pdfs/546_5995318606_Line_5_SxS_SM.pdf
You probably just have a plugged drain hole/tube under the freezers evaporator coils.
Clear the plug, also check that the drain tube is not clogged where it empties into the tray under the unit.
It is a good idea to flush it out with a 10% bleach solution. This will kill and hopefully flush out any crud in the tubing.
A turkey baster comes in handy here. Just be careful to not overflow the drain tray.
