mrgetmm1
#1 Posted : Thursday, March 4, 2010 9:04:59 AM(UTC)
mrgetmm1
Dryer takes multiple cycles to dry clothes. If I remove the high limit thermostat, the burner stays on all the time. If I put it back in, the burner seems to cycle to much. Is this normal operation for thermostat or is it bad?
bizkid23
#2 Posted : Monday, March 8, 2010 12:50:58 PM(UTC)
bizkid23
Groups: Expert
It sounds like your regular thermostat is out and your dryer is cycling on overload from the high limit thermostat. I am assuming that when you take the high limit out of circuit you are bypassing it by connecting the wires to each other?
Hope this helps.
mrgetmm1
#3 Posted : Tuesday, March 9, 2010 4:50:27 AM(UTC)
mrgetmm1
Replaced both high limit and cycle thermostat.Still no luck. And I am shorting the wires to test. I guess I'll check the flame sensor next?
Continuous low flame slow gas dryer (Dryer Repair)
by Toddd 9/24/2012 6:27:29 PM(UTC)
