Rboom
#1 Posted : Monday, March 8, 2010 12:07:34 PM(UTC)
Rboom
The new compressor for my Ice Machine came with a new drier. It is sealed on both ends. What is the proper way to open the ends of the drier to install the capillary tube and the condensor tube?
Rboom
#2 Posted : Tuesday, March 9, 2010 3:57:04 PM(UTC)
Rboom
Well, here is what I did. Used a tubing cutter to cut both ends off the new drier and then welded it in within 15 minutes to avoid too much moisture contamination. FYI, you should remove the rubber plugs in the new compressor in this order...pressure, suction, and service. If the plug will not pull out, heat it just a LITTLE with a butane torch. Replacing a compressor and evaporator assembly in an ice machine is pretty easy.
GE Monogram Compressor Replacement (Refrigerator & Freezer Repair)
by utfandg 12/23/2021 1:49:44 PM(UTC)
Ge refrigerator compressor replacement equivalent (Refrigerator & Freezer Repair)
by dmv 4/6/2018 11:42:25 AM(UTC)
samsung compressor replacement precharged with oil or empty? (Refrigerator & Freezer Repair)
by bluewater32 8/29/2016 11:16:58 AM(UTC)
samsung compressor replacement (Refrigerator & Freezer Repair)
by jwpson 8/21/2015 7:56:46 AM(UTC)
Compressor replacement (Refrigerator & Freezer Repair)
by j.wanty 8/31/2014 2:35:07 PM(UTC)
Fridge not right since compressor replacement (Refrigerator & Freezer Repair)
by Brhodgins 8/12/2014 8:19:06 PM(UTC)
GE Profile Refrigerator Compressor Replacement (Refrigerator & Freezer Repair)
by Out of My Element 8/19/2011 2:17:07 PM(UTC)
by lapseal 6/26/2010 10:11:52 AM(UTC)
Compressor replacement help (Refrigerator & Freezer Repair)
by Billyb08 3/24/2010 3:10:56 PM(UTC)
by Ted@BourgoyneEnterprises. 11/15/2008 9:31:34 PM(UTC)
Wine Cabinet (Refrigerator) Compressor Replacement (Refrigerator & Freezer Repair)
by bcaln1 6/30/2008 10:04:41 AM(UTC)
Maytag Refrigerator compressor replacement (Refrigerator & Freezer Repair)
by marster37 5/29/2008 5:00:59 PM(UTC)
compressor replacement help (Refrigerator & Freezer Repair)
by kcaaac 11/10/2007 1:32:06 PM(UTC)
