mamacitizen
#1 Posted : Sunday, March 7, 2010 3:58:18 PM(UTC)
mamacitizen
I am trying to remove the oven control panel off of my Whirlpool stainless steel double oven RBD305PRS00 because the display panel is no longer illuminated. I looked around on here and found the suggestion to check that out. I have taken off the side trim pieces and unscrewed the 2 screws on either side of the control panel. At this point, it doesn't appear to be easy to remove the panel. I don't want to bend the steel. Is there a special trick to removing the panel?
Thank you.
#2 Posted : Monday, March 8, 2010 3:42:27 AM(UTC)
Removing control panel and installing new control board (Oven Repair (including Ranges and Cooktops))
by devronh 3/4/2014 6:27:03 AM(UTC)
Removing Control Panel Wall Oven (Oven Repair (including Ranges and Cooktops))
by Germanyjon 4/30/2013 6:45:26 AM(UTC)
Removing control panel (Washer Repair)
by Grady White 9/16/2012 8:20:11 AM(UTC)
Need help removing control panel and front panel to get at the drain pump (Washer Repair)
by jthenne 2/16/2011 11:43:38 AM(UTC)
by cbelt 1/4/2011 5:00:58 PM(UTC)
Need guidance on removing control panel (Oven Repair (including Ranges and Cooktops))
by NCAmy 10/30/2009 1:59:29 PM(UTC)
