hochhaus
#1 Posted : Sunday, March 7, 2010 6:40:12 AM(UTC)
hochhaus
I just bought a new LG French door refrigerator. It is running I would say more than 50% of the time. No kids living at home so it is not opened that much and seals are all new. I had a Kenmore before and it did not run that much. I had an LG tech come out and look at it and he said that the new refrigerators have smaller compressors so they run more and also have a shorter life span. Is this true? Maybe it is but this is annoying and I find this hard to believe. In todays technological gains, everything is smaller but performs better so I still think something is wrong.
#2 Posted : Monday, March 8, 2010 3:24:03 AM(UTC)
The newer refrigerators have very good insulation so the compressors are sized much smaller than the older ones, so the compressor run time may be just normal.
I would crank the controls to a lower temerature and measure the freezer temperature, should be lower than zero degrees.
