should i be able to check countinuity across each connection and get a reading. if no reading is part bad.
Originally Posted by: marko 123  should i be able to check countinuity across each connection and get a reading. if no reading is part bad. If no reading the part is definitely bad. The thermister will change readings with temperature so it could be bad even with a reading.
THIS FORUM IS DEAD!!!!!!! |
