marko 123
#1 Posted : Sunday, February 28, 2010 8:32:25 AM(UTC)
marko 123
should i be able to check countinuity across each connection and get a reading. if no reading is part bad.
broncorider
#2 Posted : Wednesday, March 3, 2010 2:24:11 PM(UTC)
broncorider
If no reading the part is definitely bad. The thermister will change readings with temperature so it could be bad even with a reading.
#3 Posted : Wednesday, March 3, 2010 3:11:33 PM(UTC)
Here is the tech sheet.
http://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%208564549.pdf
It gives the thermistor specs
